1 - 18 of 18 Posts
I have just created a log file (005) - it should be boost.
Now looking at the data in excell I have idle speed, engine load, vehicle speed and oper cond. How do I find out what boost I was running for that log?
Im very very new at vagcom so please take it easy on me!
Not sure Roy, just playing really. I'm running Revo with SPS3 set to High Boost 9 and Timing 6, Milltek turboback, CAI and a forge DV007P.
Thats equating to 20.7psi, would that be about right?
Do the figures indicate any loss in boost to you?
Expression Intentionally Blank
Could be
Sorry don't know what happened there everything locked up. What I was trying to say was
Could be natural loss or even misreading sensors. As you suggest could even be a tweaky DV!
I ain't no effin padawan
looks bang on to me garry. Your holding 1.4bar in the midrange , and .88bar at the top end. exactly what i'd expect. the requested boost is higer than the actual boost at the top end as the wastegate is nigh on shut, and the turbo just can't shift that much air.
log maf airflow and i bet it peaks in the low 170g/s region
Gary,
Take a look at Vortex. They have had quite a few graphs on there in the past showing requested vs actual boost.
20psi sound pretty good to me. Much higher than that and you'll be hitting the dreaded limp mode.
Chris
Quote: posted by pope1 on 02/02/2004 00:24:42
Gary,
Chris
Not on a revod car you won't. My car ran 23Psi for quite a while, with no limp. They're smarter than the average bear.
Gary maf airflow is block 2 or 3 from memory.
Yes the AGU doesn't have a MAP sensor, the only thing you can do is to add a boost guage to the car.
You can get some idea on how well it is boosting by logging the max MAF reading in g/s. Which is supposed to loosly follow the actual WHP.
Don't buy a cheap boost guage as they aren't that acurate.
Cheers. I really want to build my own because I would like to put a red digital LED display in one of the switch blanks on the dash but I'm having trouble finding a display small enough. As soon as I find something suitable I should be in business.
I know that there are quite a few other alternatives but there is nothing else that rocks my boat apart from replacing the whole trip computer display with an enhanced one. Can't remember the exact cost of doing that but it was significant.
1 - 18 of 18 Posts
