if i was running my car idle and i unpluged the maf sensor, should i hear a difference in the idle of the engine? as when i pull the lead of my maf there is no change?thanks
You probably wouldn't notice a difference at idle, but if you take it for a run and you don't notice much difference either, the MAF will probably need replacing. Do some logs in VAG com if you can, you should get about 120g/s for a healthy MAF.
When I replaced the MAF on my 1.8T, the car pulled so much stronger and was more responsive - well worth doing if it's original.
Hi my maf got wet when i fitted a viper induction kit and my car became a little dangerous would not pull at all.
if you unplug it on idle from my experience the revs should drop for a sec or two then pick up i got a bosh service exchange from g&s cost me about 85-90 pound.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Volkswagen Mark IV Forum
