1 - 10 of 10 Posts
Hi, I'm a bit of a noob when it comes to this but hope I don't sound too stupid :) I'm getting a machine polisher and it comes with different pads, what's the difference between the coarse and soft pads? When would I use what?
Any help would be great, chris
what are the make of pads and what machine you getting. if your a noob do not get an orbital polisher. coarse pads will have a greater cut than softer pads. with the polish and pad combo, always start with the least cut and work your way up.
The softer pads are for finishing, the coarse for more abrasive work. I've got a linky somewhere that will help you out
Thanks for the replies, makes more sense now :)
Not sure on the model think it's called a kestrel, or something like that.
It sounds like you might have bought the same as me - Kestrel DAS-6?
It's the DA one that you'll need to read up on if you've bought the DAS-6. Happy reading!
+10 points to Dave who is on fire :D Also thanks for the Linky I got a DAS 6 myself at xmas but not busting it out till the weather improves.
With your car being black, you'll need a really soft pad to finish the polishing, I can't remember what the stuff we've been using to finish (Had some work in a car repair/painting garage) as without it the black just goes swirly as hell.
You probably know already but just in case, keep the pad nice and moist when polishing, use a bit too much to begin with just so you know how much water to use (Use a spray bottle) so you don't burn through the paint.
1 - 10 of 10 Posts
