Doubtful its the dmf, it can be fuel quality, when was the filter last changed? Try some injector cleaner in the next tank of fuel too, and try a premium fuel like shell/bp rather than supermarket. This is the most likely cause, after that there is;
Fuel Pump could be getting older/worn, try turning key on and off a few times hearing the pump prime each time, then start the car and see if its any better.
Coolant temperature sensor could be on its way out
Or injector seals could be a little worn, but then you would expect car to be a lot smokier.
Or a glowplug thats not as effective, meaning that this cylinder has to 'catch up' with the rest if you get what I mean, so its almost like running on 3 cylinders for first few seconds.
All that being said my old pd130 could sometimes be a little rough at idle for first few seconds, was never anything 'wrong' with it
