1 - 20 of 28 Posts
Found this on Elsa, thought some of you guys may find it usefull.
Engine list
Engine codeAEHAGNAGU
Engines?Petrol enginePetrol enginePetrol engine
Manufactured From 10.97From 10.97From 10.97
Exhaust emissions fulfil EU2 standardD3 standard ? NoteD3 standard ? Note
Exhaust emissions warning lamp nonono
No. of cylinders / valves per cylinder4 / 24 / 54 / 5
CapacityI1.61.81.8
OutputkW at rpm74/560092/5900110/5700
TorqueNm at rpm145/3800170/3500210/3750 to 4600
Bore? mm81.081.081.0
Strokemm77.486.486.4
Compression ratio 10.310.39.5
Injection/ignitionSimos 2.2Motronic M 3.8.5Motronic M 3.8.5
RONmin.95 Super unleaded ? Note95 Super unleaded ? Note95 Super unleaded ? Note
Self-diagnosis yesyesyes
Catalytic converter yesyesyes
Lambda regulation yesyesyes
Exhaust gas recirculation nonono
Turbocharged nonoyes
Engine codeAGZAHWAKL
Exhaust emissions fulfil D3 standardEU 2D3 standard
No. of cylinders / valves per cylinder5 / 24 / 44 / 2
CapacityI2.31.41.6
OutputkW at rpm110/600055/500074/5600
TorqueNm at rpm205/3200131/3200145/3800
Bore? mm81.076.581.0
Strokemm90.275.677.4
Compression ratio 10.010.510.3
Injection/ignitionMotronic M 3.8.3Magneti Marelli 4 AVSimos 2.2
Exhaust gas recirculation noyesno
Turbocharged nonono
Engine codeAKQAPEAPF
Manufactured From 10.97From 05.99From 05.99
Exhaust emissions fulfil D3 standardD4 standardD4 standard
No. of cylinders / valves per cylinder4 / 44 / 44 / 2
CapacityI1.41.41.6
OutputkW at rpm55/500055/500074/5600
TorqueNm at rpm131/3200126/3800145/3800
Bore? mm76.576.581.0
Strokemm75.675.677.4
Compression ratio 10.510.510.3
Injection/ignitionMagneti Marelli 4 AVMotronic ME 7.5.10Simos 3.3
Exhaust gas recirculation yesyesyes
Turbocharged nonono
Engine codeAPKAQAAQN
Manufactured From 11.98From 09.98From 10.00
Exhaust emissions fulfil EU2D3 standardEU 4
Exhaust emissions warning lamp nonoyes
No. of cylinders / valves per cylinder4 / 24 / 55 / 4
CapacityI2.01.82.3
OutputkW at rpm85/5200110/5700125/6200
TorqueNm at rpm170/2400210/1750 ... 4600220/3300
Bore? mm82.581.081.0
Strokemm92.886.490.3
Compression ratio 10.59.510.5
Injection/ignitionMotronic M 5.9.2Motronic ME 7.5Motronic ME 7.1
RONmin.95 Super unleaded ? Note95 Super unleaded ? Note98 Super unleaded ? Note
Turbocharged noyesno
Engine codeAQPAQYARZ
Manufactured From 09.99from 10.98From 09.99
No. of cylinders / valves per cylinder6 / 24 / 24 / 5
CapacityI2.82.01.8
OutputkW at rpm150/620085/5200110/5700
TorqueNm at rpm270/3200170/240210/3750 ... 4600
Bore? mm81.082.581.0
Strokemm90.392.886.4
Compression ratio 10.510.59.5
Injection/ignitionMotronic ME 7.1Motronic M 5.9.2Motronic ME 7.5
RONmin.98 Super unleaded ? Note95 unleaded ? Note95 unleaded ? Note
Engine codeATNAUEAUM
Manufactured from 02.00from 02.00from 10.00
Exhaust emissions fulfil D 4 standardEU 4 standardEU 4 standard
Exhaust emissions warning lamp noyes ? Noteyes
No. of cylinders / valves per cylinder4 / 46 / 44 / 5
CapacityI1.62.81.8
OutputkW at rpm77/5700150/6200110/5700
TorqueNm at rpm148/4500270/3200210/1750 ... 4600
Bore? mm76.581.081.0
Strokemm86.990.386.4
Compression ratio 11.510.59.5
Injection/ignitionMagneti Marelli 4LVMotronic Me 7.1Motronic ME 7.5
RONmin.98 unleaded ? Note98 unleaded ? Note95 unleaded ? Note
Exhaust gas recirculation yesnono
Engine codeAUQAUSAVUAWP
Engines?Petrol enginePetrol enginePetrol enginePetrol engine
Manufactured from 06.01from 05.00from 07.00from 07.01
Exhaust emissions fulfil EU 4EU 4EU 4LEV 1
Exhaust emissions lampyesyesyesyes
No. of cylinders / valves per cylinder4 / 54 / 44 / 24 / 5
CapacityI1.81.61.61.8
OutputkW at rpm132/550077/570075/3800132/5500
TorqueNm at rpm235/1950 ... 5000148/4500148/3800235/1950 ... 5000
Bore? mm81.076.581.081.0
Strokemm86.486.977.486.4
Compression ratio 9.511.510.29.5
Injection/ignitionMotronic ME 7.5Magneti Marelli 4 LVSimos 3.3Motronic ME 7.5
RONmin.95 unleaded ? Note98 unleaded ? Note95 unleaded ? Note95 unleaded ? Note
Self-diagnosis yesyesyesyes
Catalytic converter yesyesyesyes
Lambda regulation yesyesyesyes
Exhaust gas recirculation noyesyesno
Turbocharged yesnonoyes
Engine codeAXPAZDAZH
Manufactured from 05.00from 09.00from 09.00
CapacityI1.41.62.0
OutputkW at rpm55/500077/570085/5400
TorqueNm at rpm128/3300148/4500170/2400
Bore? mm76.576.582.5
Strokemm75.686.992.8
Compression ratio 10.511.510.5
Injection/ignitionMotronic ME 7.5Magneti Marelli 4 MVMotronic ME 7.5
Exhaust gas recirculation yesyesno
Turbocharged nonono
Engine codeAZJBADBCA
Manufactured from 05.01from 10.01from 01.02
No. of cylinders / valves per cylinder4 / 24 / 44 / 4
CapacityI2.01.61.4
OutputkW at rpm85/540081/580055/5000
TorqueNm at rpm172/3200155/4400126/3300
Bore? mm82.576.576.5
Strokemm92.886.975.6
Injection/ignitionMotronic ME 7.5Motronic MED 7Motronic ME 7.5
Turbocharged nonono
Engine codeBCBBDEBEH
Manufactured from 11.01from 05.01from 09.01
No. of cylinders / valves per cylinder4 / 46 / 44 / 2
CapacityI1.62.82.0
OutputkW at rpm77/5700150/620085/5400
TorqueNm at rpm148/4500270/3200172/3200
Bore? mm76.581.082.5
Strokemm86.990.392.8
Compression ratio 11.510.510.5
Injection/ignitionMagneti Marelli 4 MVMotronic ME 7.1.1Motronic ME 7.1.1
RONmin.98 unleaded ? Note98 unleaded ? Note98 unleaded ? Note
Exhaust gas recirculation yesnoyes
Turbocharged nonono
Engine codeBFHBFQBJSBML
Manufactured from 06.02from 05.01from 05.02from 10.03
Exhaust emissions fulfil EU 4EU 4LEV 1EU 2
No. of cylinders / valves per cylinder6 / 44 / 26 / 46 / 4
CapacityI3.21.63.23.2
OutputkW at rpm177/620075/5600177/6250177/6250
TorqueNm at rpm320/3200148/3800320/2800-3200320/2800-3200
Bore? mm84.081.084.084.0
Strokemm95.977.495.995.9
Compression ratio 11.2510.511.2510.85
Injection/ignitionMotronic ME 7.1.1Simos 3.3Motronic ME 7.1.1Motronic ME 7.1.1
RONmin.98 unleaded ? Note95 unleaded ? Note98 unleaded ? Note95 unleaded ? Note
Exhaust gas recirculation noyesnono
Turbocharged nononono
Engine codeAGPAGRAHF
Engines?Diesel engineDiesel engineDiesel engine
Exhaust emissions fulfil EU 2EU 2EU 2
No. of cylinders / valves per cylinder4 / 24 / 24 / 2
CapacityI1.91.91.9
OutputkW at rpm50/420066/400081/41500
TorqueNm at rpm133/2200 ... 2600210/1900235/1900
Bore? mm79.579.579.5
Strokemm95.595.595.5
Compression ratio 19.519.519.5
Injection/ignitionSDITDITDI
CNmin.494949
EPC system yesyesyes
Lambda regulation nonono
Turbocharged noyesyes
Charge air cooling noyesyes
Engine codeAJMALHAQM
Manufactured From 05.99from 10.97from 11.98
Exhaust emissions fulfil D3 standardD3 standardD3 standard
CapacityI1.91.91.9
OutputkW at rpm85/400066/375050/4200
TorqueNm at rpm285/1900210/1900133/2200 ... 2600
Compression ratio 18.019.519.5
Injection/ignitionTDI (unit injector)TDISDI
CNmin.494949
Turbocharged yesyesno
Charge air cooling yesyesno
Engine codeARLASVASZ
Manufactured from 09.00From 09.99from 11.00
Exhaust emissions fulfil EU 3D3 standardEU 3
CapacityI1.91.91.9
OutputkW at rpm110/400081/400096/4000
TorqueNm at rpm320/1900235/1900310/1900
Compression ratio 19.519.519.00
Injection/ignitionTDI (unit injector)TDITDI (unit injector)
CNmin.494949
Turbocharged yesyesyes
Charge air cooling yesyesyes
Engine codeATDAUYAXRBEW
Engines?Diesel engineDiesel engineDiesel engineDiesel engine
Manufactured from 02.00from 05.00from 05.01
Exhaust emissions fulfil EU 3EU 3EU 3 + D4 standardLEV 1
No. of cylinders / valves per cylinder4 / 24 / 24 / 24 / 2
CapacityI1.91.91.91.9
OutputkW at rpm74/400085/400074/400074/4000
TorqueNm at rpm240/1800 ... 2400310/1900240/1800 ... 2400240/1800 ... 2400
Bore? mm79.579.579.579.5
Strokemm95.595.595.595.5
Compression ratio 19.018.019.019.0
Injection/ignitionTDI (unit injector)TDI (unit injector)TDI (unit injector)TDI (unit injector)
CNmin.49494949
EPC system yesyesyesyes
Lambda regulation nononono
Exhaust gas recirculation yesyesyesyes
Turbocharged yesyesyesyes
Charge air cooling yesyesyesyes
1) From 05.98
2) Also possible to use unleaded RON 91 but with reduced output
3) Exhaust emissions warning lamp fitted but not operational
4) Super unleaded RON 95 also permitted, but with reduced output
Hmm
Nice thread, anyone know why the R32's have a few differences?
Hafizur
Different countries, different engines,
probably down to Fuel qualities, and also different emission laws.
American R32's have some sort of exhaust re-cirulating thing in their spare wheel well for example, they also got a larger diameter throttle and MAF which is lead to believe to produce more power over UK cars.
My engine is a BFH engine, which I'm guessing is the same for all uk mk4 R32's
Wow! For a VW newbie, this is wonderful info. Now, I need to work out which is mine?? I have a 2002 1.6 litre, station wagen, auto, factory 17" alloys, factory leather, etc. How do I tell which engine is my 1.6 ?? The car seems to go like the clappers, beyond what would seem a typical 1.6.
Any advice would be most valued.
Regards
Ray
Guess you are from the states???
Anyway, the engine code is the first 3 characters of the engine number. Look in the boot (or whatever it's called in the states (where you put shopping!!)) and lift the carpet. On the side where your spare wheel is there is a little white sticker. This will tell you the engine code and what options were fitted to the car at manufacture.
You ain't seen me, right?
damn good post there, useful info
1 - 20 of 28 Posts
