The only problem with them eh............apart form them shining accros the road on dip, dazzling other road users and meaning you cannot see anything on the N/S.......??[*-)]LHD ones will fail the mot and thats the only problem with them... you can get them through the mot by sticking the stickers on them you use for driving abroad or failing that do what I used to do and stick the standard headlights on fro the mot
I am afraid that is not true. This is only a function on some aftermarket modular headlamp conversions that allow you to rotate the module in order to achieve LHD and RHD beam patterns.Its a good reason to get gas discharge headlights as they can be swapped left to right by moving a lever inside the headlight..[:'(]
Not too sure about that mate!! If you drive a RHD car then you should have RHD headlamps and therefore passing an MOT is not a problem. The stickers that you talk about are available to cut off the light that would blind on coming traffic and I don't believe that you would be able to put these on a LHD set of headlamps and get it too pass an MOT otherwise everyone would have the option of doing it?Thats not strictly true LHD lamps can pass an mot if you use stickers to adjust the beam pattern... they dont have to kick up in the correct direction to pass they just arent allowed to kick up in the wrong direction. Simch have you ever had a set of LHD lights? the beam can be adjusted enough to prevent blinding other drivers I had a set for over a year and never got flashed and visibility was fine... not sure why you felt the need to take the p*ss with the fog light comment, I was just answering the question based on my personal experience
I have a rhd car. why would I need or want lhd lights.Thats not strictly true LHD lamps can pass an mot if you use stickers to adjust the beam pattern... they dont have to kick up in the correct direction to pass they just arent allowed to kick up in the wrong direction. Simch have you ever had a set of LHD lights? the beam can be adjusted enough to prevent blinding other drivers I had a set for over a year and never got flashed and visibility was fine... not sure why you felt the need to take the p*ss with the fog light comment, I was just answering the question based on my personal experience
You make me laugh Simch, I sense some sarcasim in your response but I like your opnion!!I have a rhd car. why would I need or want lhd lights.Thats not strictly true LHD lamps can pass an mot if you use stickers to adjust the beam pattern... they dont have to kick up in the correct direction to pass they just arent allowed to kick up in the wrong direction. Simch have you ever had a set of LHD lights? the beam can be adjusted enough to prevent blinding other drivers I had a set for over a year and never got flashed and visibility was fine... not sure why you felt the need to take the p*ss with the fog light comment, I was just answering the question based on my personal experience
Read baker21's comments above. the lever on the more modern LHD lights merely stops the dazzle, it does not move the beam, it reduces the beam where it may dazzle. So you get poorer overall performance, hence that's why i suggested the foglights to get some light back.
I seriously cannot understand why anyone would want poorer performing headlights just so they "look cool" when parked up!!!!!!!!!!
Surely modding cars well should be a balance of both performance enhancement and aesthetics enhancements, and ideally both?
But for me, it would be performance all the time over "looks". Nice if you can have both, but to go for an unusualy headlight reflector or whatever, to the detriment of the lights actual working, just seems ridiculous, potentially damgerous and illegal to boot.
Maybe you should take the lights out completely or paint them body colour for that smooth look...... and then just drive in the daytime?
We have gone off on a bit of a tangent here. I picked up on your original quote, that the ONLY thing against them was MOT. It just is not true that the ONLY downside is MOT as the post above would suggest.my sides are positively splitting
Well you will know for next time, then! [Ok maybe I should have worded my first post differently... it should have read "The only problem I PERSONALLY found with them was the MOT, but theres ways around that" The fact is I answered this post because it was a subject I could offer an opinion on based on personal experience. If someone has a different opinion or advice then that's fine, discussion is what these forums are for, however had I known that some of those with a different opinion were going to lace all their replies with unecessary & tbh rather tedious sarcasm I would have kept my opinion to myself.
