You only changed the hinges
Taken from DT
Important Notes: Notes: A,D,F,H,J
About this product
LSD is the first company worldwide who offer a complete range of specific fit hinges to give your car the spectacular 'Lambo-look' Highly engineered to tailor fit your car, installation is simple - just bolt on in place of your original hinges.
The hinges have 3D movement allowing accurate re-fitting and adjustment of the doors, ensuring panel gaps and lines are perfect.
Your door will first open outwards to a pre-adjusted angle and then smoothly it will be guided upwards by the high pressure gas rams.
Your original door latches and locks are retained ensuring no wind noise or leaks.
Features, sensational Lambo style look, engineered for each specific application, ready to install - Easy, fast installation, no welding or paintwork necessary.
When choosing your vehicle doors please be aware of the notes relating to the fitment these are as follows:
A: removal/replacement and slight modification of the wing may be necessary.
D: Wiring harness extension is necessary.
F: The standard indicator in the wing has to be slightly modified or replaced.
H: Each kit will be supplied with a gas spring which is balanced for the original door. For heavier than normal doors (e.g with big ICE installations), stronger gas springs can be ordered at an additional cost.
J: Not for vehicles with door airbags.
