I was hoping that somene may have had experience with a faulty lambda sensor .
My girlfriends 2.0gti keeps chucking fault codes on VAG com
2 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
On other ocasions ,, it just shows just the sensor fault only,,,and is recorded as " No signal " "Intermttent "
On normal steady driving ,,no faults and no problem occurs,,,,but as soon as you take it on the local bypass , near here , and do some fast driving or rev it hard ,,,,,,,,it goes faulty ,, and because of the " system too lean " code ,, MPG goes silly,,, it drops by a third.
I have checked the connections ,,with no success,,,the car also had a new MAF last year.
So is it new lambda sensor ??
And i guess it the , front of cat one too ,??
At ?90 + vat ,, I dont want to make the mistake of getting and fitting one ,, if its not that at fault .
Help Guys !!
Simon [
2 Faults Found:
Help Guys !!
Simon [
