1 - 1 of 1 Posts
Hey guys, I spray tinted my rear lights last week following some advice on an audi forum. I masked off the clear circle and sprayed the red bit a few times then a couple of coats of clear lacquer. Then I removed the masking tape and gave it 2 more coats of lacquer to seal everything in. But the lacquer on the clear part has formed a texture and has given it a frosted look. Luckily I only did the inner/boot part of the light so the big outer ones are fine (and look great!). Is it possible to remove the lacquer or smooth it down so the lights are clear again? I will attach a pic when I get home.
cheers guys.
1 - 1 of 1 Posts
