1 - 20 of 79 Posts
Hi!
This is orginal topic and few fellos have helped me so i decided to write mini DIY to help others.
Due of some bubbles on my chrome i have to do this:
Bubbles on both headlight, i dont know why. Maybe because my left side leveling motor have burn too. My internal wirings is also a mess. Im thinking to make new ones.
Levelling motor:
1. Remove front bumper
2. Unsrew 4x torx to release headlight,2 upp and 2 down.
3.Remove all bulbs and Brake the glass!
I used hammer. First i used knife and hammer, but i broke knife´s blade. Glass is very very hard to brake. It took 15-20min hitting to broke/one headlight.
I also used cartong box. beware of glass, wear decent gloves and eye protectors!!!!!
4. Remove rest of glass by hands (Gloves!!!) and try to pry those with screwdriver
5. Remove all silicone on cover.
Now it should look like this:
6. Unscrew upper manual adjusters
7. Unscrew 2 srcrews that holds levelling motor (look the video, on backside.)
8.Remove this part, it is on front and around headlight (sorry my english ends here :D)
9.Remove these from around of lens. On back side is 2 pins that have to push. Release first that what is closer to center.
10. Remove blinkers orange cover by pushing 3 clips on backside.
11. Remove outer part from blinkers orange cover.
12.Remove lens reflector
13. Remove lens.
14. Protect all parts that you dont want to paint!
15. Sand #600 sandpaper so the chrome is gone.
16. Paint, use extra thin layers. (i used heatproof mattblack) and give it dry about 2h between layers. I painted 8 layers to lens covers. Other parts 3 layers.
17. Install the levelling motor and xenonbulb connector first!!!
18. Install rest of parts reverse order.
Grab beers and enjoy
http://i592.photobucket.com/albums/tt2/MTBEV6/IMG_0657.jpg
http://i592.photobucket.com/albums/tt2/MTBEV6/IMG_0684.jpg
Yes those are oem... Where i can get new glasses? In here (Finland) isnt any supplier...
You'll have to get hold of a second set of lights and cut the plastic off the glass. Think you can use standard GTi lights (genuine) as a donor item.
I have second set on my home but those are hella`s V-wannabes. Can i use depo/FK glasses? I found some in ebay.co.uk (spare glasses)
That looks like something has got too hot, to make the silver covering bubble.
Smashing the glass is the only way to get it off. Either buy some oem standard headlight on cut all the back off till you have just the glass left, or buy some depo style headlights, they come apart easier in the oven.
Yes, but on both xenons??!! Maybe i have wrong bulbs or something? You never know when buying on ebay
TEAM 88 MOTORSPORT
looks like someone may have run them with overated (higher than 35W) ballasts to get more light output. I think it would be unusual in normal applications. unless someone else knows any different?
x2
the glass is lethal, so wear decent glove when breaking and cleaning the glass out.
My only regret is not using better glass on mine. That something I'm going to do this year, replace the glass
could this be due to moisture getting into the light and bubbling it? seems odd though especially on oem xenons.
mtbe, have you ever noticed any moisture (water droplets) on the inside of the glass?
Nobe, no water or nothing moisture. The weirdest thing is both and same time!!! I changed alternator, could it give too much voltage or something? BTW this is car with oem halogen and changed with kufatecs adapter to xenon. Is it some how possible it gives more juice on lights, even my bulbs are fogged...
I have Kufatec adapters on mine and dont have any problems with them.
Does seem strange, as if it was moisture in the light it would just evaporate. That looks like the plastic has melted.
This is only fault that i found...It is inside leveling motor:
Otherone is ok.
Other weird thing is that vw says it cannot be change (leveling motor). It is about 15min job to change. Bosch Control, headlight aiming
Part Number: 0 307 853 304/ 1j0 941 295A, if some needs on future.
What i the best way to broke the glass? Hit the screwdriver through? And what it the best way to sanding those? how about paint? Spray can?
Oh my god this glass was thick!!!! It took 15min to hit with!!
upper adjusting mounting point. it is clips that holding it on.
If someone needs it in future
1 - 20 of 79 Posts
