1 - 11 of 11 Posts
Who knows anything about this?
Im looking to do my 3g i phone which is on ios 4.1 but want to know what software to use
Also do i lose all my contacts. apps, messages etc when i do this?
iv heard from elsewhere to visit a site called:
jailbreakme.com
apparently thats the easiest was to jailbreak the phone. visit it and follow the instructions.
you will also need to get a program called cydia
i dont think you can use jailbreakme.com if youre on 4.1, limerain should work however greenpoison has less bugs. you should be able to back up your contacts with itunes but not sure about apps, once youve jailbroken you can easily put them back on anyway
Have downloaded the greenpoison jailbreak but it just wont go into dfu mode.
What am i doing wrong, im doing it just as it says on the screen
yes but does jailbreakme work on 4.1? if it does then ofcourse will be easier but i dnt knw if it does, i had limerain and greenpoison, limerain was a little easier when actually jailbreaking, greenpoison should work aswell but mite take a bit longer, i did a 3g a few months bak bt cnt remember wat i used, u might need to use redsnow if all the others dont work
1 - 11 of 11 Posts
