i would like to get the waste gate chattering sound on my golf, like the scoobys and evos have, i dont want a crappy dumpvalve wooosssshhh thow, any one got any info that could help me ???? cheers!
I heard a while back that the chattering sound is the turbine momentarily stalling. Someone on here said it, though it was a while ago. Please correct me if i'm wrong folks.If you want chatter, disable DV.. but this is'nt advised.
If you want woosh, consider an induction kit, Carbonio, AEM, RamAir etc
chatter is BAD[:S]
I believe that a diaphram dv will give you a similar sound unlike the P-Tsssssssssshh sound common with piston dv's.i would like to get the waste gate chattering sound on my golf, like the scoobys and evos have, i dont want a crappy dumpvalve wooosssshhh thow, any one got any info that could help me ???? cheers!
I've just bought a 1.8T GTI and have noticed a kind of whistling noise during gear changes (fluttering maybe) is this the same thing and should I be hearing it? I've also noticed the car hesitating a bit and then it seems to pick up (during light throttle), I quite like the sound but I thought that maybe something is wrong somewhere......
any advice greatly appreciated,
By reading some posts on the site sounds like its the diverter valve and that it may be shot, should I be taking it back to the dealer and getting them to exchange it for a new'un?
Thanks,
Sticky.
I'm pretty damn sure it is mate. The british rally-x cars make the same noise too.to get the proper wastegate chatter don`t you need an external wastegate?
i`m sure this is unique to some turbos and i know the standard ones on the golf don`t have it.
is the chatter your on about the fluttering noise on rally cars?
I think the CL in the code must mean closed loop - which i'm prettyI've got the flutter happening on my 1.8T, so based on this thread i've had a look at the Forge Motorsport web site.
The problem is they several valves all at about the same price, they
all have the same text and all the pictures look the same but they have
different product codes. Could someone tell me the difference between
these??
FMDV006, FMCL007, FMCL006, FMCL007P [:^)]
Smoshea
I spoke to Forge recently and they said if i fitted the Optimus Diaphragm Valve in reverse it would make a waste gate chatter sound rather than fitting the forge DV007P witch would make the typical woosh noise. Alos forge aredoing a 10% discount at the moment and the cost of the Optimus Valve is ?109.86 inc p+pi would like to get the waste gate chattering sound on my golf, like the scoobys and evos have, i dont want a crappy dumpvalve wooosssshhh thow, any one got any info that could help me ???? cheers!
