i want a new exhaust system for to increase my performance but i dont want a noisy system, the quieter the better, standard sound would suit me. is the miltek a noisy system? i want a full system including cat and down pipe.
regards rob
Milltek exhausts are quiet, they only sound louder than stock on the V engined cars with the centre silencers removed, before I took the centre silencer out of my 4mo the standard Milltek system was only marginly noiser than stock, highly recommended.
I am pretty sure someone on here must have sound sample of a milltek on an 1.8T?
After only one day I'd say noiser than I would like. It's not really loud but at the moment is much more boomy than I would like and drones particularly below 2000 rpm. Above 3000 rpm the noise is not so prominent for some reason and the car definitely picks up much quicker above that speed. I have some fitment issues to get resolved next week but if the noise does not improve I'll try going back to the stock rear box and see what difference that makes to sound and performance. A bit disappointing at the moment because it just sounds as if I have an exhaust with a hole in it. Oh BTW, the turbo spools much quicker now and that bit does sound good.
I'm really hoping that it will get quieter because at the moment I can't live with the noise. I've already fitted some extra sound deadening material under the carpet in the boot to try and improve things in the interim. I've also listened to some of the sound clips that others have done and while mine sounds similar, it does seem more boomy and a little crude at the moment. I always thought that the Milltek sounded very cultured (but purposeful) and that's what I want to achieve.
i have a turbo back miltek on my 1.8T and although it is louder than standard it is not boomy or ott in any way imoa. buy the performance it offers is great and i dont think you will beat a miltek..
cheers Starry....
Just fitted mine today,full system with sport cat.It spins the turbo up much quicker and gives it a little more in the mid range,the noise is only slightly noisier than standard-a bit wolf in sheeps clothing,not boyoish.A must have....now for Jabba....
My turbo also spools much quicker and the difference in performance above 3000 rpm is significant.
Fitted a Forge TIH this morning and booming below 2000 rpm was reduced. Whether the two are related I don't know.
Can't understand why mine is as it is unless (a) a lot of noise is being trasmitted to the cabin via vibration/resonance or (b) something hasn't been fitted right (maybe a leaking clamp problem) or (c) something was damaged in transit. I'm inclined to suspect (a) or (b) as there were no dents on any of the pieces. Anyone got any suggestions please?
Cheers Wilko. Will get that looked at on Wednesday. That silencer is also banging on the bottom of the car when the system is cold and the guys at the exhaust centre thought the clamps were pants. Maybe a new clamp will do the trick.
Quote: posted by Spin 150PD on 02/08/2004 12:34:55
[^]Upgraded to Turbo back from cat back this weekend and I dont think the car is any louder, very satisfied and car now revs cleaner and higher, never heard a bad report about milteks before now [8)]
Nice one Martin! [:D]
The DP itself does not appear to create any noise. You can hear the turbo spooling (sounds good) but that's it. All my noise seems to be coming from the cat back.
Judging by all the experiences that the rest of you have had, I'm remaining optimistic and will investigate fitting issues.
Having said that, there are a few similar comments in this thread
http://forums.vwvortex.com/zerothread?id=1501848&page=1
Yes and no! Let me translate for you:
Resonator (res) = mid silencer
Muffler = rear silencer
I think it is posible to get a Milltek without the resonator in the UK (check Stewart) but it's not standard as far as I know.
Took my car back to the exhaust centre this morning. Found that the resonator was touching the heat shield on one side and the pipe between the resonator and the muffler was touching the bottom of the car. Hence vibration, knocking when cold and a lot of resonance being transmitted to the cabin (the booming noise I've been hearing). After adjustments things were a LOT better. Car sounds almost stock when cruising but definitely growls at WOT and there is a little tingly vibration at higher rpms. The acid test will come later when the car has cooled down and I take it out again. Overall much better than before and starting to live up to the Milltek name.
I also fitted a Samco TIH at the week-end and the combination of improved turbo input and output is significant. I was waiting for these mods to be complete before deciding whether to do anything about the brakes. After this morning's brief drive I feel a front and back TT brake upgrade coming on when funds allow.
