So, while fiddling about with my shiny new VCDS cables, I took a look at the Instrument Cluster's soft coding, trying to ascertain why my washer fluid warning doesn't sound at the appropriate time, and got a result I wasn't expecting.
The soft code I have is 17414.
Going off the tool-tip (below), and info I had from elsewhere, the last three digits were what I was expecting, but I wasn't expecting the 17, I was thinking it'd be 01, or 05.
I DON'T have a VW navigation system (aftermarket head-unit courtesy of previous owner, but the PR code list says the car had a Gamma radio unit only), so I wasn't expecting to have a +16 for the "secondary display". However... I DO have full FIS clocks and a multi-function steering wheel.
So my question is, can anyone confirm that the screen from the full FIS clocks counts as "secondary display" for the soft coding, or do I have BS coding on my cluster?
