I started with standard keyblade with no remote locking and I retrofitted it. I reckon it's probably either my best mod or one of my best mods to date (for anyone who know's how heavily modified my car is, you'll see the significance in that). One of the reasons this mod is so good is because it allows people with standard keys to switch and then delock their cars.
I'll update this thread a bit when I can be bothered but i'll stick down the parts needed and the diagram and it means a few more of you can have a go at it if you want. Most of this install is common sense but if you have trouble understanding the diagram let me know and i'll spoon feed the information to you. I also have interior sensors and headliner looms for sale if anyone wants to install the motion sensors in their car. If you already have remote keyfob locking and alarm but no interior sensors it's a very easy retrofit to put them in.
Parts needed
CCM (the one with 2 plugs, a 23 pin and a 15 pin)
Siren
interior motion sensors
Sensor deactivation switch
headliner loom
Fuse 144 and Fuse 111 (both attach to bottom of relay plate)
Some wiring and pins from a donor car is always useful. You can use the diagram below to find out what pins you need.
T15 (15 pin plug on donor CCM, preferably cut out wth pins and some wire to solder too)
Key fob to code to the CCM.
New keyblade to fit the new keyfob.
There are 2 plugs in the CCM. Your car will already have a single plug CCM with the T23 plug fully wired. You just need to add the 15 pin plug in.
Total cost of this mod is typically between £100 - £300 depending on where you get parts.
T15 = The 15 pin connector on the CCM.
T8e = The 8 pin connector at the A pillar. This is from the headliner loom.
T32 = Blue connector on cluster
T32a = Green connector on cluster
Parts needed
Siren
headliner loom
