Hoping for some help regarding a problem I'm having installing some replacement clocks. I'm using this guide from ross-tech: http://www.ross-tech.com/vag-com/cars/Immo3-cluster-swapping.html
I have the 5 digit SKC for both clocks which should be sufficient to do the swap. However I have a problem when I get to step 9 as vagcom (303.1) only has the option to use the 7 digit SKC.
I was under the immpression that this can be done with either 5 digit or 7 digit SKC's.
Any ideas if an older version (or newer USB version) has the option to use the 5 digit SKC for this step?
