1 - 20 of 23 Posts
Visited my mate yesterday who runs a tyre business.
He filled the S03?s with Nitrogen yesterday. Seems it will maintain a constant pressure and stop the tyres expanding at speed. [:|]
<o:p> </o:p>
I?ve tried to provoke them but haven?t seen any difference yet. Good job they?re not Michelins! [:p]
mmm thats not far from me well about a 30 min run ......cheers
Steve is a top bloke and very handy to know for wheels tyres and all that as well. He has a very tidy S3 and a little music studio there so its always groovy to hang around. If you are making the trip Jason let me know and we'll meet up again.
I work in aviation and we use Nitrogen in all aircraft tyres. As you say, you don't need to pump tyres up all the time like air, it also handles temp change much better, keeping a constant pressure-even if you locked the wheels and created a flat spot, it is far less likely to blow out on you.
I realise there is probably some kind of placebo effect but I do believe the car is more stable at very high speed. Also I don't seem to lose pressure ever whereas I did with air.
Now using RE050A's in place of the S03's.[:D]
i have been running this for the last 5 years lol
I helps with tyre where and the tire will remain at a temp throught the range of driving as it does not expand when it gets hot under load.
I was first used for filling winter tires in Germany
Using this and a nice steady 29000 miles on 1 set of cheep nankan shoes so i can confirm IT IS GOOD STUFF
you can top up with normal air but it is advised to change it every so often and like stated above the tires are not as prone to leaking due to the fact that structure of the gas it larger than air.
SWAT LOL
Andy
It is just a marketing ploy... We use in aviation, in part due to the higher pressures which are involved in the undercarriage system, ie landings. Nitrogen is inert and more resistant to large heat differentials, which is prob the main reason for use in F1.
Nitrogen is also used in aviation for another reason which is not applicable to road or track bound vehicles. Most wheel hubs on aircraft are made out of magnesium for weight saving. This reacts with moisture to corrode the hubs, the nitrogen we use is of the same spec as hospital stuff, IE it is very pure and has a very very low percentage of moisture in it. It's not used primarily for its inert properties although this is a fantastic side-effect. Both Jets and Helos use it and both have very different tyre operating temps.
/lecture
/smart-arse
1 - 20 of 23 Posts
