Guys this is how to code a new remote without using VAGCOM
How to synchronise a new remote keyfobs
You'll need two keys to do this
1. Place your first key into the ignition and turn to the second notch (do not start the car)
2. Now close the door and place your second key into the handle lock
3. Turn the key to the lock position and let it spring back to the central position.
4. Hold down the Lock button on your new remote, you may hear a bleep from the car
5. Now unlock the car using the key in the barrel and remove, then take your first key out of the ignition
6. Close the door
7. Your remote should now be coded
6. Close the door
