1 - 20 of 32 Posts
Quote: posted by Tom White on 11/04/2005 10:50:35
You should see how low it goes with people in!
[:O] Do you not have any problems with the ARB?? I'd have thought you would the way it is now, let alone with extra people in it!
It's the Anti-Roll Bar. You usually get problems occuring with the ARB when lowering more than about 45mm. Most people you'll find on here usually upgrade to the Eibach ones, they have bigger hoops than standard ones and therefore no more problems! [;)]
Quote: posted by Tom White on 11/04/2005 14:31:37
Evilhomer - you got any side on pics of yours?
http://www.uk-mkivs.net/forum/topic.asp?TOPIC_ID=49969
Those are some older pictures. The car is dropped a little lower now, but also I run 225/35/18 rubber, which deceivingly makes the car look a little higher (rolling radius is slightly reduced.)
In addition the camber on the back is quite far inboard, which again is decieving as to ride height (Camber is being resolved at the mo)
[:D]
1 - 20 of 32 Posts
