21 - 25 of 25 Posts
CHADDY V6! Im after the same FK Highsport....are these the 35-55mm ?569????
and if so is yours set at the lowest on the photo
Quote: posted by cage on 03/09/2004 22:19:26
I am currently running 19's lowered by 50/55mm on H&R suspension.
Is that with springs only or did you uprate the shocks too?
I not to sure really think so,got 55mm drop at the back (could get more if i remove the spring adjustment locking nut[:D])and the fronts on the photo are little less around 45mm at moment (worried about turning the wheels [:O])
There the'FKVW51's but they are for the 4motion don't forget. (This low on a 1.8T you will need new ARB's [:(])
So can you just confirm this for me again, you can run 19's with a 55mm drop front and back and still get full lock without any scrubbing? Just want to make sure because this is what im planning to do to mine! Oh, P.S. I'm only after springs at the moment, not coilovers, will that make any difference?!
21 - 25 of 25 Posts
