Quote: posted by Essex Escy on 03/03/2005 20:53:17
ok......how do i know if i have one already then???
sounds silly i know, but i've never looked.......
possibilites are you will know if you have one if...
a) do you have a lap belt on the rear centre seat, if so then you should have a rear arm rest.
b) do you have a diagonal seat belt (i.e comes from top of centre seat) if so then you may not.
c)also if you have a centre head rest this may be another reason you wont have one.
May have something to do with the safety pack though???
Just check and look if you cant see a big square thing in the middle of the seats that you can put your finger in and pull down then sorry you have not got one.
To modify your seats to add one you will require a whole new seat backing plate, (the metal bit you see from your boot) as this contains the mounting.
Good Luck
