Hi.
Golf Mk5 57 plate.
I have changed the headlight bulb and managed to eventually change the full beam bulb, but how the heck do you get the small (501) sidelight bulb out....please
If its similar to a mk4 one, just give it a good tug NOT from the wires but from the base of the bulb and the bulb and the holder should pull out. Easy to replace.
If its similar to a mk4 one, just give it a good tug NOT from the wires but from the base of the bulb and the bulb and the holder should pull out. Easy to replace if you are lucky enough to have the hands of a shrew.....
edited for accuracy [;)]
I cant even get my fingers in, will try what others have said and remove the bumper. Thanks for the answer tho
If its similar to a mk4 one, just give it a good tug NOT from the wires but from the base of the bulb and the bulb and the holder should pull out. Easy to replace if you are lucky enough to have the hands of a shrew.....or have a tiny little 1.4 engine which means you can stand in your engine bay.
edited for accuracy
If its similar to a mk4 one, just give it a good tug NOT from the wires but from the base of the bulb and the bulb and the holder should pull out. Easy to replace if you are lucky enough to have the hands of a shrew.....or have a tiny little 1.4 or 1.6 engine which means you can stand in your engine bay.
edited for accuracy
Thanks for all the advice but you cant even get into the area so Im not going to bother, thanks again tho.
Anyone got any ideas on my heater question?
My bro's side repeater went couple of weeks back, Was easy god dam peazy!
I have a MK4 and was pretty much the same, push the light to either side the letft or right as they have two metal clips on both side that have a certain amount of flex in them.
So basically your pushing or pulling either was and then getting your fingr nails behind and pull.
