If the headlight looks like this.....
Then its got xenons! [Y]
wheres the difference mate?
Between what?
i mean those are just projector headlights sorry to jump in
They are essentially projectors... but they have xenon internals and a shutter inside the lens (which accounts for the bi-xenon name tag)
Could of swore it was all four last time I checked. Will take a gander before I leave work tonight when it's dark.Tinners... i thought it was either or!
Push stalk backeards for the xenon full beam (no halogen)
Pull stalk forward for flash to pass halogen.
The bixenon doesn't work on mine because i cannot be bothered to run the extra wires required!![]()
The Bora has a Xenon projector for dip beam and a second halogen bulb for main beam. The main beam bulb takes the place of the fog lamp in the light assembly, so any Bora with Xenons has no foglights. At least for the OEM Xenon units. If you go with the Xenon / HID kits in the standard headlights then the H4 fitment bulb has a solenoid shunt system which moves the bulb back and forward to give different beam patterns (high & low), similar to the Bi Xenon in question I think.<snip>
Bora's that come with xenons are bi xenons both high and low beam on one bulb H4
Ian
