1 - 4 of 4 Posts
Just found out it was my rad leaking on both bottom corners which was causing a puddle on the floor and coolant loss on my 2.0 tdi
im still not sure how to remove..Once the front bumper is off do i have to remove slam carrier? the ac condensor? or do i not need to take that off?
regards
ps. sorry if its a stupid question
remove front bumper
drain ac system
drain coolant
unbolt two torxm 30 screws at the top of the radiator left and right
drop radiator pack out the bottom
ps you may want to unbolt rad fans first
pps the only stupid question is the one not asked [:D]
thanks. someone said that you dont need to remove the ac rad. and the coolant one is in the engine side?
1 - 4 of 4 Posts
