HELP
560 Views 4 Replies 3 Participants Last post by  bigdave237
My car broke mk4 golf, and wouldnt start put a digognostics on and a fault has came up P00609
and wont start
need help asap
1 - 5 of 5 Posts
Okay more info needed here! Does it turn over does everything light up? What noises is it making etc. Diagnositocs is okay but you need to look at the problem first!
yeah more info on the problem pls is that the only code that came up on the diagnostics? and what diagnostics did you use?
yes sorry, the ignition comes on all lights come on dash but go off after 6-8 secs? and theres a small beep type noise?
and unsure on the the diagnostics used im afraid,
he originally came to do a altenator change, as the battery was drained and the car died on way home from the community centre.
but before he could do that we swaped over the battery to start it up, however car will not start turns over but not starting
all relays are working fine could it be the imobilizor?
:/ any help much appreciated
1 - 5 of 5 Posts
