1 - 6 of 6 Posts
i have recently aquired vagcom and also a bora 130 highline, looking to mess about with things like the locking/unlocking settings and anti high jack and anything else i can. i am unsure how to access this using the vag com and need a few pointers. i have used vag com but not for these functions and i am aware there are a few comfort settings that can be played around with.
any help would be great and is there a thread on this already
thanks, is this all i can do? i have seen a couple of mk4's running about with the outer 2 parts of the high level brake light working with the tail lights, ia this an option or a fault with the car?
also is there a feature to do all the windows up from the remote?
and finally can you have miles to empty on a mk4/bora?
From other posts I have read the brake light thing is a fault,
As for the windows feature its enabled with a program called VDS Pro,
Miles to empty is done with Vagtacho on immo 3 VDO clocks
thanks for your help guys will have a play around, was thinking about the vag tacho lead from e bay but unsure if any good or safe? am i right in thinking this will program keys too?
1 - 6 of 6 Posts
