1 - 12 of 12 Posts
Idiots shopping list for a stage 2 and 3 golf gti turbo...... Main goal is to be between 270-300bhp
FMIC
Large Bore milltek or the like
Big Brakes
thanks in advance - 7th 12hr night shift in a row and cant function to write my shopping list
jock
Well what else do you have already would be nice to know then people could tell you what you need or have missing from your list maybe buddy?
ko3 turbo
apr FMIC
312 brakes
coilovers
airfilter relocated to behind front bumper
Revo stage 1 map
all hard pipes and forge silicone
forge re-circ dv
forge actuator
then comes the question do i upgrade the turbo...... but dont want a ko3s or ko4 dunno why just think if i'm changing turbos i may as well go big instead of 6months down the line changing it again
cheers jock
German Engineering at its Best
basically
gt28rs turbo with all necessary bits
70mm maf housing
big FMIC and hard pipe kit
uprated clutch
550cc genesis injectors
uprated rods
acl race bearings
lighten and balance bottom end
i just did a similar build in a passat. currently running it in its a nice but not cheap set up
JJ
How much did all that cost? I've done the clutch and single flywheel and the intercooler and hard pipe already
machning work, labour, software, gaskets, shells, piston rings, head bolts and the odd wear and tear part on the engine came just short of £2800.
on top of that comes the eliminator turbo kit with high flow manifold, injectors and h-pattern rods which were directly sourced in the us by the customer so i cant comment on that but would assume around $2300.
this is assuming your block is still in the tolerances to be honed and does not need to be rebored with oversized pistons.
forgot to mention high flow de-cat or race cat exhaust system is needed as well.
JJ
London Refurbs'
Could always go hybrid K03? Alot of people on SCN running over 270 with that and its what ill be doing.
Peter
Peter
depend what you intend to use the car for and how long you want them to last. im sure same figures are achievable for less but how long will they last?
JJ
London Refurbs'
They still only run at 20 psi for those levels so i reckon they should last aslong as stock if treated with decent oil and warm up/cool down periods are decent.
As you know its all about the mapping. Id tune it down a bit so its never running full potential so should last a little longer.
Ill be using the car everyday. Some horror stories with these but they dont cost the world and arent rare or anything so theres bound to be some.
Peter
1 - 12 of 12 Posts
