1 - 1 of 1 Posts
I can't open the passenger door from inside or outside, the outside handle just behaves as if the door is locked. If I try and open from the inside, when I pull the handle it raises the lock pin, when I let go the lock pin goes back down to the locked position.
When I press the switch on the drivers to lock/unlock the car, the passenger door pin does not raise. I have plugged the computer in, looking a group 009 "Central locking feedback" for passenger side it says "Safe"
A fault code scan picked up the following:
Friday,14,January,2011,16:30:44:40962
VCDS Version: Release 10.6.0
Data version: 20100630
Address 46: Central Conv. Labels:
Control Module Part Number: 1C0 959 799 B
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 366829D6382F
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
37-00 - Faulty
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-00 - Implausible Signal
Address 46: DTCs cleared
It took two attempts to clear the fault codes, door still won't open.
Now what do I replace first?
The CCM or the door lock?
How can I get the door open?
1 - 1 of 1 Posts
