1 - 20 of 20 Posts
Connect the centre vents upto the heated rear window switch's wires..
The passenger side vents can be powered by these too - you will need to run extra wires across to them.
The drivers side vents can be powered by the wires of the dashboard dimmer controls
Thanks again guys.
Could someone clarify which colour wires I need to tap into
Driver side can connect to the dimmer control: blue wire to ??? and brown wire to ???
Centre and passenger vents can connect to the rear window button: blue wires to ??? and brown wires to ???
1 - 20 of 20 Posts
