1 - 20 of 24 Posts
Well my 19" BBS ch's arrived last week[:D]
ET 30 and they are 8.5" wide running a 235/35/19" tyre.
My R32 suspension is standard but the tyres are rubbing on the inside of the wheel arches[:'(]
What is up????
I have run 19's before on my mk'4 TDI... and I never had a problem[:S]
Any ideas???? anyone else had the same problem????[:$]
I have lost a load of my tyre sidewall today and I am very stumped.
Martyn
Have you not got spacers? would this help?
I know someone who was running 235's on the front and they would rub without spacers. But he put 225 tyyes on instead which stopped the rubbing, but it must have still been damn close!
My Golf is now running 19" with 235 x 35 tyres and no buffing issues although it is only lowered 30-35mm but I can see the possibility of issues with running it lower as my front ones just about sit within the arches
· Premium Member
I had this probem with my old GTI. After having H&R coilovers installed, my ET32 BBS RC's need 5mm spacers to clear the height perches on the coilover struts. This reduced the effective offset of the wheels down to ET27.... Causing the outer edge of the tyre to catch on the metal arch lip, on suspension compression - shredding the corner edge side wall over time.
Two options 1) Have the arches trimmed / rolled... or 2)Run a different tyre, maybe going for a different lower profile.
I ended up getting some 225/45/18 Goodyear Eagle F1 tyres and this sorted the problem. The GSD's had a shallower side wall and this saved the day for me.
Either way its going to cost ya mate [:cool:]
· Premium Member
Cheers tabs...
Looks like I will get them rolled cause I want to run coilovers later on[:p]
Now I peeved off[:'(]
Get the arches trimmed. Rolling can sometimes lead to paint defects due to the heating process involved.
/Tabs' tip of the day.
Ive got these too and they are the best tyres Ive ever had. Plus the rim protectors are brilliant
Cheers tabs...
Nah, all you need is the guide on VW Fixx telling you how to roll your arches... with a baseball bat! [;)]
Martyn do you know if anyone other than Carnassour rolls arches or whatever as I could does my front ones as they only just!! go inside the arches does the large  man (Magee) do them in the Car Care centre Lisburn
1 - 20 of 24 Posts
