Ooh that's a hell of a swap. The injection system is completely different on the two engines. The turbo hoses are all different, as is the intercooler. There's nothing straight forward about it I'm afraid, and yes you'll need the ECU, clocks, all engine sensors and ancilliaries, wiring loom, then you'll need to either have the keys from the old car to swap the immo transponders or have your old keys recoded to the new immo system in the clocks / ECU.
Gearbox, I'm not certain. Should fit, but that's irrelevant if you can't get the rest of the engine bits above.
