1 - 6 of 6 Posts
Hi,
Ive got a mkiv gti. In the recent cold the window froze shut even after alot of deicer. Being a monkey i have separated the mechanism from the glass.
The window stayed up and the mechanism went down. Now the window works but it is loose in the mechanism.
How do i go about reattaching it properly. I remember in the mk3 there was just a clamp to tighten up.
I spoke to VW who just said i will need a repair kit, but surely i can just reassemble it, it still works fine now, but need to secure the glass better.
Thanks for the help in advance,
Ed
Thanks for the replies
yep still goes up and down.
it does come out of the clamp about 5mm, but still in it just, when u move it down from the acceleration. try to use my hand to ensure it stays together.
Sounds like i can remove the door card lower the window a bit and then releat the clamp a bit, relocate and tighten the?
1 - 6 of 6 Posts
