Was in the car today, and noticed that there was heat coming from the heating system even though it was not turned on via the climatronic. Upon further investigation, I noticed that the temp on my heater was set to 28 deg when I do put my heating on, so I turned this down to "Lo" and shut off the climatronic (put it to "off"). I then noticed the cooling system for the car was giving out cold air !!
Why does my climatronic give out air depending on the temp its set at "even when it is in the off mode" ?? This quite annoying as you can expect.
