1 - 5 of 5 Posts
Hi,
My car is a 2005 and has never had the oil changed in the gearbox. I can't believe VW says the oil is lifetime!
I've found the 17mm drain plug but I am struggling to find the filler hole. Does anybody know where it is please?
The car is a 1.6 FSI with the HBM gearbox.
Thank you for the help.
(y)
Check next to where the driver's side drive shaft mounts to the box, on the side of the flange nearest the rear of the car. Also a 17mm plug.
Cheers Adam for the help! (y)
Any ideas what the torques settings are for the plugs? Is it 25nm or 30?
Cheers :)
1 - 5 of 5 Posts
