1 - 4 of 4 Posts
Today i was wiring in a new HU and 6x9's
Something sparked when a live wire touched the HU casing
Since then the hazards and the indicators dont work at all
all the fuses are fine
any suggestions please??
You've probably killed the hazard switch which contains the indicator relay.
Want a good suggestion? ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYSALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS ALWAYS disconnect the battery when you're doing this sort of work,next time it could be alot more expensive.
Chris.
cheers for the help mate
ill bear the battery suggestion in mind i thort it was just for people that was scared of getting a small electric shock haha obviously not
cheers anyways
You can't get an electric shock from 12 volts,it's just advice taken from many years of experience.
Chris.
1 - 4 of 4 Posts
