Guys.....
I put a thing on the ''group buys you want to see''
But dont think anythings been done - so i went and did it myself -
Its such an easy thing - and will cost ?15 tops
3B4 839 167 - Housing
3B4 839 879 A - GRU Cap Primed
METAL DISC - FOC
Those are the bits you need
Dont forget the paint kit which will include your colour paint & lacquer....
Do a search on here to find out how to....
but its as simple as:
Pop out the plastic gromet on the side of the door which is just behind the lock effectively.....
Grab your torx - 6-7 turns to undo - NOT TOO FAR THO OTHERWISE IT FALLS OUT (& you have to remove door card)
as your loosening - keep pulling the handle - you will notice it all getting looser - eventually the lock section can be removed - just slides out
Carefully - with long nose pliers put the METALDISC (or 5p as some ppl use) into the recess you can see at the back of the hole youve just removed the lock from.
Insert you new - alloy cast blank lock
Push on the newly painted blanked off cap
Do your torx up
Put gromet back
Job done.............................
Took me 5 mins tops
Reflex is a hard colour to get right.....
Maybe worth a trip to the breakers - and nick one of a rear door already done?just a thought - Hope this helps guys
Lets stop the buggers....mind you if its not the lock its the window...but they are cheaper !!!!
Happy Days[
