Golfy Wagon Rear Badge/Lock Removal and Paint
So I'm off for a few days and I'm skint so time for some poor man mods. Yesterday, I debadged the tailgate and I kinda like the clean look...intended to paint the letters satin black and refit but no doublesided tape + no cash × kinda like it = leave it as it is.
So, next step was to remove the rear badge/lock and paint in satin black and the plastic backing in matt black. Sort of a how to here but since I have no pc or laptop, I'm using my phone to take pics and write this. No fancy arrows or rings round bolts n stuff ok?
This is for the Mk4 Estate but the removal bit should be the same for the hatchback. Should you try to follow this guide and you break something or die, I accept no responsibility.
Pic no 1.
Remove the inner tailgate trim. Remove the single screw in each hand hold, they are only wee short ones and I used a pozi 1 bit to remove them. Careful not to drop them.
Pic no 2.
What you're doing is pulling the cover off. Couldn't do that and take pics ;-) Best to start at the left or right side of the boot catch, about 3" to left and right of it are the first of the "jesus" clips. Get mid and large size flat screwdrivers and cover with some cloth. Using the smaller of the 2, pry up the edge of the panel and then slide the bigger screwdriver in where the clip is and lever it out. Some force is required and when it pops, it is loud....jesus!! Then do the opposite side of the catch. Get a friend to hold the tailgate or...if you're like me and have no friends, work your fingers under the panel edge and pull the panel with one hand while holding the tailgate with the other. Try to pull straight out as opposed to at an angle. Bear in mind that if it is cold, the plastic will be brittle so be careful.
Pic no 3.
This shows the position of the clips to each side of the panel. There are 2 more along the top/middle.
Pic no 4.
This is a clip and the broken part of the holder on the inside of the panel, it's 2nd in from the side on the too edge but shouldn't be a problem. If there were more broken, then I'd look into sorting it.
So the panel should be off. Don't be afraid of it, once you have a corner and the centre unclipped, it should come off with a single yank.
Pic no 5.
Removing the lock and badge.
With the panel removed, you will see the wiper motor and below it, the locking mechanism and then the tailgate catch. There is a rod that attaches on a balljoint on the end of the lock, pop this off with a flat screwdriver. The rod hangs loose in the boot catch so just remove it and set with your other bits. I use a magnet when I'm removing and reusing little screws and bits. You can get magnetic parts trays but I am El Cheapo ;-)
Pic no 6.
Disconnect the lock motor connector blocks. At this point, put something at the boot catch that will prevent the tailgate from closing. Yes, it's an estate and you can climb through and push the rod to open it but....hassle.
Pic no 7.
Not the best pic but if you look at the back of the lock/badge, there are 3 Torx screws that hold it in place. Roughly at 2, 6 and 10 o'clock. You can see the 10 o'clock one just above the wire to the left. I think they are T25 or T27....I couldn't find either so used a small flathead bit :-\ They aren't that tight. Use a magnetic driver or a magnet to stop you dropping one of them.
With the 3 screws removed, the lock should pop out. Mine was a bit welded in with 14 years of MucknDirt™ so be gentle. Before you go any further, wipe around the hole....ooerr...so it's nice and clean for refitting.
Golfy Wagon paint badge prep...
So the lock/badge is out. Give it a wipe off to remove the MnD™
If you want to paint yours, walk this way.... if not, assembly is the reverse of removal
Pic no......no I can't remember what number we're on.
Get the badge off the mechanism. I removed the 2 silver screws on the back plate, the rubber backing gasket is still on the badge in that pic. Peel it off gently and clean it up for refitting.
I faffed around for a bit trying to get the chrome badge off the backing plate and I almost had it but I thought I was being a bit brutal. Then I realised that the chrome is attached to the black plastic backing plate. Wedged a screwdriver between the goldy back plate and the plastic backing plate and off it came. It's held on with doublesided spongy tape stuff.....err I don't have any and I'm skint....oh well, that's tomorrows problem
Pic no 9 I think...
The badge is off but still on the plastic backing plate. The badge is attached to the back plate using those melted rivet type things, you know like the plastic sticks through and then they melt the tip over? I used a 10mm drill bit and reamed the tops off the heads. Not in the drill, just held and twisted by hand. Et voila! Le badge is now separated.
Instead of painting the backplate, I'll vinyl wrap it, I'll use black but now is the time to consider another colour of your choice....If I had yellow vinyl, I would've used that as I like the contrast between yellow and black though on a silver car??? Maybe not...black it is then. And I keyed the chrome and fired a coat of Simoniz Tough Black satin on it earlier, left to dry, had a look just now and there's a wee run on it so it'll be flatted and redone tomorrow.
And that's as far as I've got today. Will update with the end result once repainted an dried.
