Golf mk4 Gti Problem Please Help
1558 Views 8 Replies 5 Participants Last post by  rOcK_oN
Hello there
Ok where to start after getting my turbo fitted replacement one i decided to get some gauge put in which all work. Some reason when I blasted it down the road it help sluggish and now if i hit 60mph it goes into wierd mode starts kangeroo'ing like it starved of fuel or a pipe come off some where fine upto 60 try go anymore wont have it, Also friend who fitted it did say some reason my turbo is boosting at 2bar which is mental is there anyone had same problem or can help please let me know
Thanks for your time
David
1 - 9 of 9 Posts
this sounds like going into limp mode? well get it diagnosted mate and you'll probably see where the problem is
hey again
so it appears my turbo is over boosting sending the car into limp mode is the only way sorting this is buy a new turbo?
As mentioned above best route to take is to VAGCOM the car and see what the issues are and go from there.
You don't have to use VAG-COM if you don't have access to it,any garage with OBD diagnostic equipment will do just fine and will hopefully give you a fault code that should save you hours of messing around.
Chris.
Ask about for someone with vagcom in your area too!!
hello again do i ask here if anyone has VAGCOM in Luton or near at all can even take car there ?
Thanks David
As I said above [brick] if this is urgent (and it sounds like it is) go to ANY local garage or mechanic who will have some sort of OBD scan tool.They won't charge much to do it and you won't be hanging around for ages waiting for an answer on an internet message board.
Chris.
As I said above
Chris.
yeah this is pretty urgent so dont bother looking for vag-com mate just find someone with any diagnostics
1 - 9 of 9 Posts
