Status
Not open for further replies.
1 - 4 of 4 Posts
Ello pepole hoping sumone can help me got my self a mk4 gt tdi on sat to my amazement an hour later the battery was flat ended up jump starting it and was fine then drive it down around for half hour to charge it up went in the shops come back out flat again so jumped it again and it was fine for the rest of the day what I have noticed is the interior light be dim as your driving along then You go over a pump or sumthing and it goes bright again like sumthing is lose so got a tester and battery was only showing 12V on start but if You rev it past a certain rpm it kicks back in iv changed alternator and battery and iv disconnected the module under the steering wheel anyone else had this problem or can help me as lost with this one and only had the car a day thanks
Done all them still no joy but had a look a just now and noticed the blue wire near starter motor was broken rejoined in now have battery light on dash and when the car started its giving 13v that seem right
1 - 4 of 4 Posts
Status
