Hi all,
I bought a golf 4 1.6 16v, 2003. Car seems to run good, plenty of power, but one annoyance is that the throttle takes long to close when letting off the accelerator.
When shifting you see the revs climb a bit before dropping and while driving you can feel the car still delivering power for a second even when you're off the pedal.
What can cause this? I'm doing a throttle body alignment later tonight to see if it helps, I have vcds and a vag com interface.
Thanks in advance,
Thanks in advance,
