1 - 10 of 10 Posts
yo this might be a bit thick but when i first got my car it didnt have this waste gate sound it only happens when its half way through boosting i let my foot off i get a waste gate sound dont get me wrong i love it but is it a split pipe or a boots leak any help will be brill even if 1 person say's ya its normal now get a grip an jog on would be sound
Its normal to hear a very small amount of noise when the turbo is spooling at full load and you let off the gas, however a full on whooshing is not normal and would indicate some kind of leak? If you do have a leak, you should perhaps have a more pronounced sound as the turbo spools up as well? Like a sucking sound? Either way, its not normal to be as pronounced as you say, especially if it wasn't there before.
Cheers.
Steve.
Livin' by the sword
Well, seeing as there isn't a wastegate fitted to the car then the noise is most likely a boost pipe split, or an air leak in the inlet perhaps. Might even be the egr assembly sticking open and air escaping through there.Mine certainly doesn't make this noise anyway.
mine does this if i think the sound you get is like i get, it does it more say if i go up a hill basically more load on engine. its always done it since i've had it 44k when i got it now on 109k no split hoses whatsoever
Ian
sound ya cheers ian put me at rest a bit more as my turbo sounds normall when spooling up i just take good care of my car so i always think somethink its wrong when its not or maybe there is ( see wot i mean lol)
yeah i know what you mean, i first noticed the sound when my friend had a 2005 140 mk v golf as a courtesy car and should me then and it was pretty much brand new back then so highly unlikely a split hose!
Ian
There has been a known issue with the turbos on the PD 2.0 engines. VW was at one time replacing turbos with excessive whine, not withdrawn this unless lack of power can be observed. A few of us on her have had their turbos replaced.
1 - 10 of 10 Posts
