Quote: posted by mattbecker on 11/01/2005 10:10:14
Quote: posted by Richy_50pence on 10/01/2005 23:24:40
you can be months trying to find out, I had some problems before and called in to see my local guy who has a basic diagnostics kit, he didnt charge me to have a look [
] but he only normally charges ?25 to have a look and tell you what comes up!
Your local mechanics college may even have some sort of testing stuff, my local one does and they will do it for free because they do it as a demonstration!
I always go EASY first, and get lucky 4/5 times!
My car is completely standard. the description of the problem is acceleration in any gear using approximately 30% throttle the car surges back and forth i.e. it is hesitant to accelerate, quite sutterly but once you tune into it it is extremely annoying. It will do it both cold and hot. CLive Atthowe in Norwich has had a look at it and he could not find anything wrong with it apart from the MAF signal was a tad low so he changed it but the problem is still there. I took the car to VW mid last year and their lead technician told me they all do that, hence why I do not want to take it back their! I have access to diagnostic kit(Lotus) which I have hooked up to the car and there are no fault codes the only thing that looked slightly unusual was the 02 sensor switching seemed a little slow.
Mattbecker, that sounds like the advance bouncing off the knock sensor, its not a misfire as such, it just sort of "pulsates" the power delivery, rather than it being smooth?
This could be an ECU issue, but is more likely a crank sensor or knock sensor issue. Again, get it on a specialist rolling road, they will see it hapening in real time and set about curing it.
