1 - 5 of 5 Posts
Ive tried searching but cant find any info.
Does anyone know how big the fuse should be for Electric adjustable seats (not heated) ?
A 10A blows straight away, a 15A lasted a day then decided to blow as soon as I pressed a button.
Im not sure if I should put a 20A in incase thats too high.
The electric seats use a 30 Amp thermo fuse, not a normal one. (same style as the electric window thermo fuse you can see at the bottom of the relay plate next to the screw terminals).
The part number of the thermo fuse is 443 937 105 A
The thermo fuse holder is 4A0 937 530 which just clips on the bottom of the relay plate.
1 - 5 of 5 Posts
