1 - 2 of 2 Posts
For some reason my fuse 5 holder 7.5 amp keeps blowing when I turn my ignition on ? The oil sensor workshop also comes on too but I have had a new sensor fitted and checked the wiring from the sensor to see if there is a break from rubbing on the driveshaft but all is good and I have tested the wire and I get 10-12volts ?
Please can someone help as I don't have my climate control and outside temp working as it runs off the same fuse which is not good in this weather !
1 - 2 of 2 Posts
