1 - 20 of 79 Posts
NooNoo
Front windscreen wiper mechanism replacement on mk4 Golf 1.8T fitted with Bosch aeros (arm type is unimportant).
Time to change: 1.5hrs at DIY speeds. Slower if you clean your scuttle area.
Why Replace?
  • Slow or juddery windscreen wipers
  • Windscreen wipers not moving at all!
  • Speed 2 = speed 1
This fault is almost always the wiper posts seizing. I have never come across a burnt out motor (nor has Leicester TPS, ever sold a motor).
Parts required
1J2 955 603 B New wiper mechanism £40 inc VAT
New mechanisms have a 'shim' that should extend the working life of the mech.
Tools
10mm and 13mm sockets on 3/8ths.
Short 3/8ths extension bar.
3/8ths rachet.
Large flatblade screwdriver.
Typical posi screwdriver.
***** YOU MAY NEED A WIPER ARM PULLER / REMOVAL TOOL AS THE ARMS GET STUCK - SEE EBAY *****
The Part
  • Barney is a pain! He chewed one of my wiper caps [&]
  • Packaging
One of the wiper posts on the new mechanism. On the old seizing mechanism the arm is almost impossible to move!
Fitting New Mechanism
Remove wiper cap offside...
  • Remove wiper cap nearside...
  • Remove wiper 13mm offside, wiggle off wiper arm (hold down at spring joint and lift near post).
  • Remove wiper 13mm nearside, wiggle off wiper arm (hold down at spring joint and lift near post).
  • Remove the pollen filter cover (helps with scuttle flexibility when removing)...
  • Remove the long bulkhead seal (just pull)...
  • Remove the scuttle starting from nearside... be careful they are brittle due to age and UV.
  • Continue removal of scuttle... be gentle! Use a warm hairdryer if very brittle.
  • Continue to ease the scuttle off the windscreen working towards the offside...
  • Take the scuttle out via the windscreen (not via the engine bay).
  • Remove the first mechanism retaining nut
  • Remove the 2nd mechanism retaining nut
  • Remove the last mech retaining nut...
  • Remove the old mechanism disconnecting the electrical conncection on the way out...
  • Remove electrical connection...
  • Side by side, old and new mech... notice the slightly bent old mech, did this removing one of the posts during a previous strip down and regrease!
  • Remove the wiper arms at the wiper post end only (lever off using a large flat blade)...
  • Undo the 3 x 10mm motor retaining nuts...
  • Remove the motor and slip the arms through the old mechanism. No need to dismantle! DO NOT dismantle.
  • I greased the new mechanism around the wiper tops to help minimise water ingress...
  • New 'shim' with the new mechanism (guessing it's to prevent water getting in)...
  • Rebuild the mechanism, threading arms through and reattaching motor with the 3 x 10mm.
  • Remember to fit the motor grommit / fastener from the old mech. New mech doesn't have one! (Well mine didn't).
  • Replace the mech into the scuttle area and refit 3 x 10mm bolts... remember the electrical connection first.
  • Try and get the fixings central, otherwise your wiper posts won't be central in the scuttle cutout.
  • Refit the scuttle (pretty much the reverse of removal). Be careful it's brittle!
  • It is unlikely you will get the scuttle totally pressed back to the windscreen - unavoidable, just doesn't go back perfectly in my experience.
  • Check the wiper posts come through the scuttle about central, some deviation is fine.
  • Refit the pollen filter cover. Note the back right corner has to go over an obstruction, use a torch and have a look!
  • Refit the bulkhead seal.
  • Refit the wiper arms/wipers using the 2 x 13mm. It may take a few attempts to get them correctly positioned.
  • Refit the wiper nut caps.
All done.
Try your new mech out, try speed 2 out for a giggle, the wipers have never moved so fast.
Nick, my wipers have always seemed a bit slow for my liking, i'll be intrested in seeing if you find the wipers work faster after this fix.
For what it's worth, which parts seize up?? is it the bits just above the wiper arm spindle?
Is it possible to remove, sand and re-grease them for a fix?
NooNoo
I've stripped down and regreased the old mech twice but this time I thought I'd treat myself to a new mech.
If your wipers seem slow and there is little or no difference between high and low speed your mech is seizing.
The procedure for regreasing or mech replacement still requires the mech to be removed from the car. Regreasing can be hard work as you have to extract the posts which are stuck solid (usually). It's managable though.
I've finally bit the bullet and bought new...
Edit: If your wipers are slow and you change the mech you will be amazed how quickly the wipers move again in high speed!
uk-mkivs
The only problem is getting the joining arms & motor in exactly the right place, if you dont have them in the right spot on the motor spindle the wiper arms wont return & sit in the right place on the windscreen when finished.
Tip - mark the joining arms & spindle with tip-pex or something, so you know they are in the right spot.
Took me 1hr to get this part right on a mates A4.
NooNoo
Absolutely, although I think there is room for improvement on factory fit position. I know mine are now concealed better by the bonnet for less wind noise and drag.
Takes about 3-5 fits per wiper to optimise!
  • Like
Reactions: Mmalkie
Even simpler-the motor arm and wiper arms should be in a straight line when at rest,same for all cars.
Chris.
NooNoo
Chris.
Even simplier you don't have to remove them!!! They slip through the mech no probs...
[Y]
uk-mkivs
Thats where I went wrong, I removed the arms at both ends.
Didn't even think about slipping them through the mech!
NooNoo
Can be done for £40 less by removing the spindle and cleaning it all up with some wire wool and 6-800grade wet and dry to remove a bit of metal to prevent it seizing up again.
Done mine must be near 2 - 2 1/2 years ago and not one issue since.
I've done the full strip down regrease three times but last time I slightly bent the mech (look closely in images). The posts can be seized solid and tough to remove.
So I've bought new this time. Also note the new 'shim' should help prevent water ingress.
I did that four times in as many weeks after mine siezed up the first time,then gave up and bought a new one.The problem with trying to fix them is once you've cleaned all the mung off,the clearance between the shaft and bush is way outside of tolerance (at a guess double what it should be),so will never retain grease properly after that.
Chris.
Hi Nick,
I've read it's easy to break the scuttle panel if you're not too careful,
What's the best method to take it off? I see in your pics you started to peel it away at the passenger side.. I take it that you start at one side and slowly work across?
NooNoo
Yes it is easy to break! It's much easier in warm weather to remove. Mine actually has a small part missing from a winter removal. The key is patience but the the aged plastic is brittle... I have never managed to get it totally flat to the windscreen either upon refitting :)
hi people iv noticed that when i put my wipers on flat out the drivers one comes over to far(slightly) and hits the post, VERY annoying. could this be as simple as taking it off and replacing it on the thread, iv never had it off and it looks like its has never been off, seems to sit ok when off [*-)]
NooNoo
Yes, as simple as relocating the wiper arm on the splines 'lower' in the rest position.
Hello,
Thanks for your brilliant instructions and photographs on how to replace the Wiper Mechanism on a MK4 Golf. Without your help I would not have been able to do this and the local VW dealer would have charge me quite a lot of money. Mine is a 1998 car and the wiper arms had never been off! I used a general purpose small 2 legged puller on the passenger side but I had to make a simple puller using 2 X 6mm bolts with the heads filled down to 2mm and the sides filled off so as to fit under wiper arm boss then made crossbar with 3 holes cetre one tapped and another 6 mm bolt to pull arm off. It was vert tight and a simple Ebay puller would have bent I'm sure!. Still, job done and a big thank you.
Bryan location Stafford.
1 - 20 of 79 Posts
