1 - 15 of 15 Posts
hey guys, quick question,
ive just fitted my coliovers but can only lower x amount before the spring hits the wheel, so i am going to
need some spacers, there 17" wheels,i havent got the other measurments of the wheel atm as its dark, will
updatetomorrow, just need to know where the best place to get them from and what do i need, ie how far does
thespring need to be clear of the tyre, i willl be getting some new wheels in the summer so dont really want to
spendloads on these,
Ive had a look on pats wheel thread but and slightly confused by it so any help would be greatful
thanks sam
hello mate give venom motorsport a call they keep a good range of spacers,i think u will only need 5mm ones if you only want to clear your coilovers,hope this helps
is it possible to make your own spacers using a laser cutting machine, or is there anything special about them, i only need 10mm on front and 20mm rear, so i don't think i need hub centric spacers.
so does this mean that i have to get a 20mm kit for the front? as i cant find any 10mm kits that are hub centric
i think 10mm track will be to much for my wheels and they will hit the arches, will i be ok fitting 5mm flat spacers to my front? or will i just have to keep it my ride height as is
oooo audi
gold 5door my fronts are the same height as your rears in the sig never touched the struts although genuine r32 wheels are 7.5j
yea my fronts around the same as rear now , rubbed with out spacers but now ther in it rubs on the arch , thats part of the reason why im getting 17s
thanks for the useful posts guys!
on my joms, im lowered all the way with the spring adjuster taken off so about 75mm i think but the front is as low as it can go atm without the spring adjuster hitting the wheel, with 5mm spacers i think ill be able to match the rears.
once again thanks for the replys
sam
1 - 15 of 15 Posts
