1 - 6 of 6 Posts
Hi guys
Got a 5 door, mk4 golf 2003
Will be fitting this alarm
Alarm
Does anyone have a wiring diagram?
I was told i also needed the diagram of the back of the fuse box.
If anyone can help me out.
I would appreciate it
There is no wiring diagram as such and who ever told you about the back of the fuse box knows less about car alarms than my mum.
Before you attempt this,do you have any experience at all in doing this sort of thing?
Chris.
Yh i know how to do all this just needed a diagram of what wires go where.
Was told by another guy to tap into the back of the fuse box wires but i dont think thats right [:(]
Isnt there anywhere that tells you which wires is for the lights, which wire is for the door contacts etc and so on?
Indicators black/white and black/green behind the hazard switch
Door trigger blue/grey in loom up nearside A pillar or CCM
Boot trigger brown/blue or brown/black at CCM
Bonnet trigger brown/red at CCM
+12 volts solid red base of relay rack
Ignition live black/yellow base of relay rack
Central locking as below....
HOW TO INSTALL AFTERMARKET REMOTE CENTRAL LOCKING
Siren wire into car through main loom grommet on nearside lower firewall.
But as with anything like this,never take the word of a complete stranger on the internet.Always test,then test again and finally do a bit more testing before you connect anything up.
Chris.
Going to fit the alarm tomorrow.
Could you help me out in regards to which wires go where?
The ones im stuck on are:
Blue wire
Yellow wire
Green wire
white wire
Blue wire
Green wire
White/Black wire
Blue/White wire
If possible can someone tell me where these wire connect to the factory wires?
1 - 6 of 6 Posts
