1 - 6 of 6 Posts
I`ve jusy bought a Xtrons TD 714 which only comes with brackets, It is not removable, so how to I fix it in, I don`t want to Hack my dash, how easy is it to remove the radio surround.
You'd be better off buying a universal double DIN cage if they don't make one for it,the bolt in fittings are normally only found on Jap cars.
Chris.
A hell of a lot more difficult than it is buy a DN cage for it.Also pointless because it doesn't have the fixings that Jap cars have to let you bolt it in.
Another reason for the cage is they won't makle such a mess if they steal it when it's easy to get out.If it's bolted in they'll still try anyway but will wreck half of the dshboard trying to lever it out.#
Chris.
i just fitted the same sort of double din i got a
http://www.carstereos4u.co.uk/volkwagen-double-din-facia-panel-and-cage-kit/autoleads-fp-17-00-volkswagen-golf-mk4-lupo-double-din-facia-panel-adaptor-2095417-330149-.php
but dvd did not fit so i had to grind the inner lip on the plastic cage
and two small grooves at the top to take the clips that attach the surrond to dvd
and just to make it sit a little further back there are 6 small spines of plastic to stand the adaptor out about 5mm not much but with these off went back and looked better
but to get all the rca's in and get it back i could not be assed to take all the bits out to get the inner cage out so i took a saw to the part that holds the cd and cassett apart at sides and bottom
pushed it all in and tis was awesome
also pushed out light in glove box and routed the ipod cable through worked well
hope this random ramble made sense to u
billy
Can you post pics of your radio?
As said above, normally ddin radios dont have non removable mountings on them so not normally a problem
1 - 6 of 6 Posts
