I have mow got round to sorting a spare wheel sub for the V5.
It encolves using the inside of the spare as an enclosure. Its a V6 Space saver also so it gives me more rome above it.
I cut the 18mm MDF to fit in the wheel well and with a hole for inside of the spare.
I then lined the spare with carpet and then masking taped over it. I did this as i will be coving the box in carpet and just the tape and fibre glass would have made it too tight to wrap in carpet also....allways thinking..[
I then covered the tape with resin and hardner mix to produce a sticky base then layed on the fibre glass and well....fibre glassed it inside and over the edge of the wood.
and have done about 3 layers so far, but have run out of Fibre glass.
Then put a heater in the boot and have left it....
What you all think so far ?
Matty
Matty
