Quote: posted by PhatPhil on 11/07/2004 15:15:11
Tried JBR. They weren't sure if the clutch kit would fit an Anni as "the USA didn't get the PD Anni". Not confidence insipring at all!
Will give Stealth a call on monday.
Phil,
Its difficult when figuring out if a product from one car, will fit a different car, and i know that the regular TDI is different from the Anniversary. Like with James' brakes...they were for the 1.8T, and would not fit on a regular TDi...yet we got them, and they fitted on no problem as it happened to be the same at the 1.8T Anniversary. i happen to think that both the anni's share the same components.
If we can be 100% sure of which clutch is suitable for the PD150, i will be more than happy to arrange a groupbuy on them for members! As im sure you will understand, it would not be ideal for you, or for us to get the parts and then find that they are in fact incorrect.
I will do some research into the different clutches for different models and see which ones are shared throughout the range. I suspect that 6 speed will share the same, as will 5 speed.
Will post back when i have the correct information!
Rich
